Greetings fellow builders ! All went suspiciously perfect for first time build ! And of course it had to start Blue Screens after 2 months!
The problem started with Lineage 2 and Fortnite open together. The mouse stopped responding to some commands within the game. Let's say it clicked on half the icons and not all of them! After a while, it would display a BSOD and restart. Some times mouse will stop working and only if i unplug and plug it again it will work ,doesnt matter if the port is the same or not. It's not a problem with the games or the mouse.
I update all bios / drivers ,run memtest86 and cinebench and all are ok ! Mouse and ports are all ok too ,checked !
After some further research in the internet i found that ntoskrnl.exe and, by extension, AV_mouhid!MouHid_ReadComplete are to blame ! Can this only be solved with a clean install of Windows? Why might this be happening? Pc is 2-3 months old ,all new and stock except ram speed on expo.
Ryzen 9900x / MSI B850 Mag Tomahawk / Zotac 5070 ti / Trident Z F5 @6000 / Crucial T500 / Corsair RM1000X / Corsair Nautilus 360 / Windows 11
New Hyper X Cloud iii wireless and 6 years old Corsair k75 lux and Logitech G502 Hero.
If you need more details, please let me know !
Thanks in advance ,Chris.
P.s I dont know many things ,i just follow some steps on internet and i try to fix it !
P.s2 Sorry for my Eng !
Is there any prog to unistall entire mouse drivers ? I did it from device manager but seems nothing happened.
