- 8 May 2008
HI all,
Got a Overclockers Titan Goliath i7 920 o/c to 3.4ghz. INstalled my g card, a 4870 x2. All running fine for a while, but now crashing with BSOD on atikmdag. It occurs at any time in games.
I have checked the heat of the card and all is fine (running at 45-60deg under load).
When the crash occurs, the PC refuses to restart for about 1/2 hour. It willg et to the windows loading screen and jsut before the login prompt it BSOD again.
I have tried updating all drivers, unloading CCC, but all to no avail. I have also tried clocking the system back to stock 2.67ghz through the BIOS. This ran stable for a while, but then crashed again.
I am at my whits end. I think it may be a graphics card hardware fault, but am not sure.
Any help you can give me before I return the G card, or phone overclockers support woul dbe ver4y gratefully received.
Michael H
Michael H
No issues swapping after that!!
