8 Oct 2013 at 18:49 #21 snips86x snips86x Soldato OP Joined 14 Nov 2012 Posts 17,997 Location Chesterfield If I disable the IGP, should this redistribute the vcore required when overclocking my graphics card?
8 Oct 2013 at 18:58 #22 wazza300 wazza300 Caporegime Joined 11 Jul 2009 Posts 27,040 Location BenefitStreetBirmingham I don't think the igpu affects anything,disabled or enabled
8 Oct 2013 at 19:46 #23 snips86x snips86x Soldato OP Joined 14 Nov 2012 Posts 17,997 Location Chesterfield wazza300 said: I don't think the igpu affects anything,disabled or enabled Click to expand... Ok just checked settings and vcore is 1.33 with and offset of +.025. LLC is at level 3. Still suggest setting offset to +0.035?
8 Oct 2013 at 20:05 #24 wazza300 wazza300 Caporegime Joined 11 Jul 2009 Posts 27,040 Location BenefitStreetBirmingham yh,then test for stability and lower later if stable
8 Oct 2013 at 20:17 #25 snips86x snips86x Soldato OP Joined 14 Nov 2012 Posts 17,997 Location Chesterfield wazza300 said: yh,then test for stability and lower later if stable Click to expand... It was fine untill i tried to push my graphics card further. May have to just push the card as far as i can on the 0.025 offset.
8 Oct 2013 at 20:45 #26 wazza300 wazza300 Caporegime Joined 11 Jul 2009 Posts 27,040 Location BenefitStreetBirmingham Yh it will,the faster the gpu the more CPU v also,as the pcie bus is linked to CPU,(thats my guess for needing more CPU v )
8 Oct 2013 at 21:41 #27 snips86x snips86x Soldato OP Joined 14 Nov 2012 Posts 17,997 Location Chesterfield wazza300 said: Yh it will,the faster the gpu the more CPU v also,as the pcie bus is linked to CPU,(thats my guess for needing more CPU v ) Click to expand... That makes sense. I'll run it as it is until the card is stable and reduce the offset by 0.005 untill its ok.
