Asus P5Q Pro Turbo motherboard
Windows 7 professional 64 bit operating system
Intel Core 2 Duo E7500 2.93GHz Socket 775 1066FSB Processor
OCZ 4GB Kit (2x2GB) DDR2 1066MHz/PC2-8500 Reaper Memory HPC
XFX HD 4890 XXX Edition 1GB DDR5 Dual DVI HDTV Out PCI-E Graphics
850w NorthQ Black Magic Flex Power Supplie
2 x 1TB Seagate Barracuda 7200.11, SATA 3Gb/s, 7200rpm, 32MB Cache, 8.5 ms set up in raid
i keep getting the blue screen of death with random error codes memory has been tested lots of times with no errors also the graphis card and cpu seems to be no problems
downloaded lastet drivers from asus
heres some of the many error codes:
installed a copy of windows 7 32 bit everything seems to work fine no crashes but i do not want to run a 32 bit operating system so please can anybody help...........
i get same errors with xp 64 bit
done loads memtest and burn test on various hardware all comes back ok could this be defective hardware here are the minidump files from win 7 pro x64
http://rapidshare.com/files/278038397/mindumps.zip.html
