BSOD help:?
2 Dec 2009
Hi all, Been a while since i last visited... So i hope this is in the correct subforum.
This problems got me truely stumped.
So hopefully someone can help before i wipe/ fresh install.
I want to play RA2 (red alert 2) on my system,
However, the game keeps causing BSOD's... I think.
sometimes installing, sometimes at the start screen, sometimes 10 minutes into a game.
I think There BSOD's ( the game freezes, playing a short sound loop, screen goes fuzzy - no responce from keyboard/ mouse)
Specs are:
Q9550 oc'd to 3.8
8gb ocz pc6400
2x HD5770
windows7 pro
So far i have:
Updated all drivers, removed OC, set game compatibility to xp mode, ran windows mem diagnosics (unlimited passed overnight)
Checked gfx temps, cpu temps, passed intel burn test fine.
After thinking it must be a dodgy game, i tried to play RA3 (which used to run fine) this also crashed in the same manner.
Now im stuck for ideas.
Any help appreciated.
Cheers
If you got a BSOD, you probably got some kind of error message on your screen, and you probably also got a crash dump. Check your windows folder for a memory.dmp or minidump and host it somewhere, along with the details of the crash, and post it here. They usually zip quite nicely.
WhoCrashed said:
On Sun 10/10/2010 17:51:30 your computer crashed
This was likely caused by the following module: hardware
Bugcheck code: 0x124 (0x0, 0xFFFFFA800832A028, 0xB2000040, 0x800)
Error: WHEA_UNCORRECTABLE_ERROR
Dump file: C:\Windows\Minidump\MEMORY.DMP
Doesn't mean a thing to me :P People out there can anaylse dumps well though, not sure if it ever gives a answer; just possibilities (my experience in the last) I've always gone to http://www.techsupportforum.com/mic...e-screen-death-bsod-posting-instructions.html
Worth a try. Though response can be slow (well few days) hell you might as well do a memtest86 over night aswell really
i already started a memtest86+.. left it running for 3-4hours.. but wasnt sure how many passes it would do, so escaped and carried on.
Does it just run infinate?
cheers
Yep it will go on forever. I think I leave mine on for like 9 tests or so. Though my last memory I sent back, i started test and got 1000s of fails within seconds :p Though the longer the better.
I've had umm 3 or 4 periods of BSOD's since I built my computer last September, talk about annoying! Since my last RAM RMA (thank god its unlimited warranty ;) 3rd set of RAM lol.
So far so good :D
Hope JcGriff gets on the case :D Don't know if its his job or like a voluntary thing; surely not as it must take a while, lots of posts, lots of analysing. Just from looking at the report.html there's so much information there! But just from the WhoCrashed I did earlier its something hardware related so mm
I'm sorry, I slept through yesterday and didn't check this thread.
It's a CPU error, looks like it's caused by an Intel stress tester that is running.\
Do you have this going in the background for some reason?
http://software.intel.com/en-us/articles/intel-math-kernel-library-linpack-download/
It could be you just happened to be running that app last time it crashed, though. If that's the case, check to make sure all your memory is of the same type and speed, and be sure the bus speed is configured correctly for everything in the BIOS. It may be as simple as a mismatch.
Code:
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [Desktop\MEMORY.DMP]
Kernel Summary Dump File: Only kernel address space is available
Symbol search path is: SRV*c:\Windows\Symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`03049000 PsLoadedModuleList = 0xfffff800`03286e50
Debug session time: Sun Oct 10 13:48:30.393 2010 (GMT-4)
System Uptime: 0 days 0:03:19.705
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 000007ff`fffd3018).  Type ".hh dbgerr001" for details
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 124, {0, fffffa800832a028, b2000040, 800}
Probably caused by : hardware
Followup: MachineOwner
3: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa800832a028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000b2000040, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000800, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR:  0x124_GenuineIntel
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
PROCESS_NAME:  linpack64.exe
CURRENT_IRQL:  f
STACK_TEXT:
fffff880`02fdda58 fffff800`03012903 : 00000000`00000124 00000000`00000000 fffffa80`0832a028 00000000`b2000040 : nt!KeBugCheckEx
fffff880`02fdda60 fffff800`031cf593 : 00000000`00000001 fffffa80`0832bea0 00000000`00000000 fffffa80`0832bef0 : hal!HalBugCheckSystem+0x1e3
fffff880`02fddaa0 fffff800`030125c8 : 00000000`00000728 fffffa80`0832bea0 fffff880`02fdde30 fffff880`02fdde00 : nt!WheaReportHwError+0x263
fffff880`02fddb00 fffff800`03011f1a : fffffa80`0832bea0 fffff880`02fdde30 fffffa80`0832bea0 00000000`00000000 : hal!HalpMcaReportError+0x4c
fffff880`02fddc50 fffff800`03011dd5 : 00000000`00000004 00000000`00000001 fffff880`02fddeb0 00000000`00000000 : hal!HalpMceHandler+0x9e
fffff880`02fddc90 fffff800`03005e88 : 00000000`00000001 00000000`00758394 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerWithRendezvous+0x55
fffff880`02fddcc0 fffff800`030b7fec : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40
fffff880`02fddcf0 fffff800`030b7e53 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x6c
fffff880`02fdde30 00000000`00666f0b : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x153
00000000`3b92fa78 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x666f0b
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: hardware
IMAGE_NAME:  hardware
DEBUG_FLR_IMAGE_TIMESTAMP:  0
FAILURE_BUCKET_ID:  X64_0x124_GenuineIntel_PROCESSOR_BUS
Just so Raist can take a look at JcGriff2 response (MVP)
Hi -
I ran 16 of the most recent dumps with timestamps from 13 Oct - 16 Oct 2010.
The bugcheck on 15 of the 16 -
0124 = WHEA = Windows Hardware Error Architecture = unknown hardware failure
Info on 0x124 - [url]http://www.sevenforums.com/crash-lockup-debug-how/35349-stop-0x124-what-means-what-try.html[/URL]
From the software end... quite a few old drivers floating around in your system.
This 2005 Asus ATK0110 mobo utility driver has cause many Windows 7 systems to BSOD to death -
Code:
[FONT=lucida console]ASACPI.sys   Sun Mar 27 22:30:36 [COLOR=red]2005[/COLOR] (42476C4C) - ATK0110 mobo utility driver [/FONT]
[FONT=lucida console]asusgsb.sys  Thu Sep 27 09:14:50 2007 (46FBACCA) - ASUS Virtual Video Capture driver - [URL]http://support.asus.com/download/download.aspx[/URL][/FONT]
[FONT=lucida console]ATKDispLowFilter.sys Tue May 13 23:03:13 2008 (482A5671) - ASUSTeK Display Lower Filter - [URL]http://support.asus.com/download/download.aspx[/URL][/FONT]
Asus Support --> [url]http://support.asus.com/download/download.aspx[/URL]
Slideshow for asio.sys update; Scroll down at Asus site - look for ATK0110 --> [url]http://cid-e5d03c221cac693f.skydrive.live.com/play.aspx/Asus%20mobo%20utility%20driver%20updates?ref=1[/URL]
Repeat same for last 2 Asus drivers.
Outdated ESET installation -
Code:
[FONT=lucida console]eamon.sys    Mon Nov 16 02:51:14 2009 (4B010472)[/FONT]
[FONT=lucida console]epfwwfpr.sys Mon Nov 16 02:46:31 2009 (4B010357)[/FONT]
[FONT=lucida console]ehdrv.sys    Fri Sep 11 01:12:55 2009 (4AA9DC57)[/FONT]
[FONT=lucida console]eamon.sys    Fri Sep 11 01:12:19 2009 (4AA9DC33)[/FONT]
[FONT=lucida console]epfwwfpr.sys Fri Sep 11 01:07:43 2009 (4AA9DB1F)[/FONT]
ESET Download - [url]http://www.eset.com/download[/URL]
Update these drivers -
Code:
[FONT=lucida console]ALSysIO64.sys Fri Dec 19 17:29:27 2008 (494C2047) - Core Temp CPU temp monitor -  [URL]http://www.alcpu.com/CoreTemp/[/URL][/FONT]
[FONT=lucida console]L1E62x64.sys Thu Jun 11 02:45:22 2009 (4A30A802) - Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller - [URL]http://partner.atheros.com/Drivers.aspx[/URL][/FONT]
[FONT=lucida console]RTKVHD64.sys Fri May 22 14:04:20 2009 (4A16E924) - Realtek HD Audio - [URL]http://www.realtek.com/downloads/downloadsCheck.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false[/URL][/FONT]
[FONT=lucida console]nvlddmkm.sys Fri Nov 20 22:40:46 2009 (4B07613E) - NVIDIA Video - [URL]http://www.nvidia.com/Download/index5.aspx?lang=en-us[/URL][/FONT]
[FONT=lucida console]nvBridge.kmd Fri Nov 20 22:09:47 2009 (4B0759FB) - NVIDIA Video - [URL]http://www.nvidia.com/Download/index5.aspx?lang=en-us[/URL][/FONT]
Old CPU-Z version -
Code:
[FONT=lucida console]cpuz_x64.sys Tue Dec 02 08:51:19 2008 (49353D57) - CPU-z[/FONT]
Uninstall CPU-Z; install new version - [url]http://www.cpuid.com/softwares/cpu-z.html[/URL]
Old Norton driver -
Code:
[FONT=lucida console]EIO64.sys    Tue Jul 21 22:34:42 2009 (4A667AC2) [/FONT]
Run Norton Removal Tool - [url]http://jcgriff2.com/NRT_N360_Removal.html[/URL]
Windbg Logs
--> [url]http://jcgriff2.net/BSOD_Logs/_99-dbug_csweatherston_Windows7x64_10-17-2010_jcgriff2_.txt[/URL]
--> [url]http://jcgriff2.net/BSOD_Logs/_99-dbug_csweatherston_Windows7x64_10-17-2010_jcgriff2_.txt.zip[/URL]
Regards. . .
jcgriff2
BSOD BUGCHECK SUMMARY
Code:
[FONT=lucida console]Built by: 7600.16617.amd64fre.win7_gdr.100618-1621[/FONT]
[FONT=lucida console]Debug session time: Wed Oct 13 17:09:10.644 2010 (GMT-4)[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:08.956[/FONT]
[FONT=lucida console]Probably caused by : hardware[/FONT]
[FONT=lucida console]BUGCHECK_STR:  0x124_GenuineIntel[/FONT]
[FONT=lucida console]DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT[/FONT]
[FONT=lucida console]PROCESS_NAME:  System[/FONT]
[FONT=lucida console]Bugcheck code 00000124[/FONT]
[FONT=lucida console]Arguments 00000000`00000000 fffffa80`0830e8f8 00000000`00000000 00000000`00000000[/FONT]
[FONT=lucida console]¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨``[/FONT]
[FONT=lucida console]Debug session time: Wed Oct 13 14:42:36.608 2010 (GMT-4)[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:11.310[/FONT]
[FONT=lucida console]Arguments 00000000`00000000 fffffa80`08388038 00000000`00000000 00000000`00000000[/FONT]
[FONT=lucida console]Debug session time: Wed Oct 13 11:54:42.348 2010 (GMT-4)[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:08.049[/FONT]
[FONT=lucida console]Arguments 00000000`00000000 fffffa80`083878f8 00000000`00000000 00000000`00000000[/FONT]
[FONT=lucida console]Debug session time: Wed Oct 13 10:38:36.938 2010 (GMT-4)[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:10.639[/FONT]
[FONT=lucida console]Arguments 00000000`00000000 fffffa80`083cf8f8 00000000`00000000 00000000`00000000[/FONT]
[FONT=lucida console]Debug session time: Sun Oct 10 13:48:30.393 2010 (GMT-4)[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:03:19.705[/FONT]
[FONT=lucida console]PROCESS_NAME:  linpack64.exe[/FONT]
[FONT=lucida console]Arguments 00000000`00000000 fffffa80`0832a028 00000000`b2000040 00000000`00000800[/FONT]
[FONT=lucida console]Debug session time: Sun Oct 10 13:17:24.755 2010 (GMT-4)[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:07.456[/FONT]
[FONT=lucida console]Arguments 00000000`00000000 fffffa80`08359728 00000000`00000000 00000000`00000000[/FONT]
[FONT=lucida console]Debug session time: Sun Oct 10 12:19:40.206 2010 (GMT-4)[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:09.517[/FONT]
[FONT=lucida console]Arguments 00000000`00000000 fffffa80`083948f8 00000000`00000000 00000000`00000000[/FONT]
[FONT=lucida console]Debug session time: Sun Oct 10 11:32:08.678 2010 (GMT-4)[/FONT]
[FONT=lucida console]System Uptime: 3 days 17:00:57.379[/FONT]
[FONT=lucida console]BugCheck D1, {0, 2, 8, 0}[/FONT]
[FONT=lucida console]Probably caused by : ntkrnlmp.exe ( nt!KiPageFault+260 )[/FONT]
[FONT=lucida console]BUGCHECK_STR:  0xD1[/FONT]
[FONT=lucida console]Bugcheck code 000000D1[/FONT]
[FONT=lucida console]Arguments 00000000`00000000 00000000`00000002 00000000`00000008 00000000`00000000[/FONT]
[FONT=lucida console]Debug session time: Wed Oct  6 18:31:19.629 2010 (GMT-4)[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:08.330[/FONT]
[FONT=lucida console]Arguments 00000000`00000000 fffffa80`083908f8 00000000`00000000 00000000`00000000[/FONT]
[FONT=lucida console]Debug session time: Wed Oct  6 16:56:25.972 2010 (GMT-4)[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:08.673[/FONT]
[FONT=lucida console]Arguments 00000000`00000000 fffffa80`08387038 00000000`00000000 00000000`00000000[/FONT]
[FONT=lucida console]Debug session time: Wed Oct  6 16:49:28.332 2010 (GMT-4)[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:08.034[/FONT]
[FONT=lucida console]Arguments 00000000`00000000 fffffa80`08337038 00000000`00000000 00000000`00000000[/FONT]
[FONT=lucida console]Debug session time: Wed Oct  6 16:31:34.223 2010 (GMT-4)[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:07.924[/FONT]
[FONT=lucida console]Arguments 00000000`00000000 fffffa80`0836c4f8 00000000`00000000 00000000`00000000[/FONT]
[FONT=lucida console]Debug session time: Wed Oct  6 16:24:50.161 2010 (GMT-4)[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:08.472[/FONT]
[FONT=lucida console]Arguments 00000000`00000000 fffffa80`07f638f8 00000000`00000000 00000000`00000000[/FONT]
[FONT=lucida console]Debug session time: Wed Oct  6 14:57:41.800 2010 (GMT-4)[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:08.502[/FONT]
[FONT=lucida console]Arguments 00000000`00000000 fffffa80`0835f8f8 00000000`00000000 00000000`00000000[/FONT]
[FONT=lucida console]Debug session time: Wed Oct  6 14:15:13.878 2010 (GMT-4)[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:09.190[/FONT]
[FONT=lucida console]Arguments 00000000`00000000 fffffa80`0849a038 00000000`00000000 00000000`00000000[/FONT]
[FONT=lucida console]Debug session time: Wed Oct  6 14:10:16.768 2010 (GMT-4)[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:00:10.079[/FONT]
[FONT=lucida console]Arguments 00000000`00000000 fffffa80`083ea8f8 00000000`00000000 00000000`00000000[/FONT]
[FONT=lucida console]Built by: 7600.16385.amd64fre.win7_rtm.090713-1255[/FONT]
[FONT=lucida console]Debug session time: Wed Dec  9 20:55:21.237 2009 (GMT-4)[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:02:06.969[/FONT]
[FONT=lucida console]PROCESS_NAME:  occttest.exe[/FONT]
[FONT=lucida console]Arguments 00000000`00000000 fffffa80`08046028 00000000`b2000040 00000000`00000800[/FONT]
[FONT=lucida console]Debug session time: Wed Dec  9 20:51:44.220 2009 (GMT-4)[/FONT]
[FONT=lucida console]System Uptime: 0 days 0:04:02.547[/FONT]
[FONT=lucida console]Arguments 00000000`00000000 fffffa80`080a7028 00000000`b2000040 00000000`00000800[/FONT]
[FONT=lucida console]by [COLOR=navy]jcgriff2     [/COLOR][/FONT]
[FONT=lucida console][COLOR=navy]        J. C. Griffith, Microsoft MVP[/COLOR]   [/FONT]
[FONT=lucida console]          [URL="https://mvp.support.microsoft.com/profile/Griffith"][COLOR=#000055][U]https://mvp.support.microsoft.com/profile/Griffith[/U][/COLOR][/URL]   [/FONT]
[FONT=lucida console]          [URL="http://www.jcgriff2.com"][COLOR=#000055][U]www.jcgriff2.com[/U][/COLOR][/URL] [/FONT]
[FONT=lucida console]¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨¨[/FONT]
He has a different memory dump than I received?
Even so, it is a standard tech response to tell a user to update firmware and drivers. Though I don't disagree with doing so, these are very general recommendations and may not address a specific issue. I'd roll with his recommendations, but would like to know if that app is running on the background.
Ye he would have. He makes you do a system performance thing and makes you run a .bat file he made up. So lots of files for him to look at! It's his 'job'
Apparently some drivers just really don't work well, he said that my old netgear adaptor driver was terrible with W7 and he had seen multiple problems with that driver and BSODs. Always a good idea to have the most up to date drivers to be safe.
Wouldn't mind knowing how to do it myself tbh. (Analysing dumps)
