Hi guys,
I'm having a couple of problems with my setup. I'm running the following: -
Abit Ip35 pro
Q6600 @ 3.2 gig (1.3 volts)
4 gig Crucial ballistix tracers (2.2 volts)
Evga Geforce 8800 GTS 512meg (stock speeds atm)
Basically im getting BSOD when booting Vista. Now i had this problem occur about 2 weeks after getting the pc and running the current Overclock (Q6600 @3.2, Memory at 1068 mhz). So i upped the MCH voltage from stock 1.25 to 1.32 volts. The issue whnt away completley for two months.
Tonight it re-occurred cant boot into windows at all BSODS on any attempts.
So i upped the mch again to 1.37 and again it now seems stable.
Is this mch voltage ok? Temperature wise my case is running around 30C, cpu is about 35-40c and the Pwm is showing about 45c.
Is my memory dying or is this just an issue with needing that little bit extra out voltage on the northbridge?
Abit Ip35 pro
