BSOD - RAM Speed. Is it hardware related?
12 Dec 2005
I do have a post in the RAM section about this but thought I'd make one here aswell as I'm unsure if it's just a RAM related issue.
This is my RAM:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-133-GL
This is my motherboard:
http://www.asrock.com/mb/Intel/B75 Pro3-M/?cat=Specifications
CPU-Z Reads:
It appears my RAM isn't running as fast as it should be. As I was advised, I enabled XMP in the bios and reset but when it got to the desktop I got a BSOD, so I disabled it and just manually set the multiplyer to 1600 but that also caused a BSOD.
I'm worried that something is wrong, I only built this system yesterday. I don't have much experience with RAM at all, do I need to mess around with the timings when upping the multiplyer to the speed my RAM supposed to be?
Could another issue be causing the BSOD?
Many thanks
EDIT - Mobo website says:
**DDR3 1600 with Intel® Ivy Bridge CPU, DDR3 1333 with Intel® Sandy Bridge CPU.
Ok I've done some Googling and from what I can see, I need to set the voltages and timings myself.
I can see all the options for this in the BIOS but I have no idea at all which voltages and timings I need to set. Can anyone please help me.
You changed "DRAM FREQUENCY"?
Try manually changing the DRAM VOLTAGE to 1.5v
What CPU do you have?
Yeah, there were 4 different settings, 1600 being the highest which I set it to. I did also set DRAM Voltage to 1.5v but it still BSOD at desktop.
CPU is i3 3220.
Many thanks
In your other thread you stated you were all up and running and was looking for ways to check for stability.
So, when you first put the system together, what exactly did you set in bios?
The system should still work, without manual or XMP, as it should run on the rams lower setting of 1333mhz.
And have you made any other changes since, prior to the BSOD?
Also, try it without the Gpu installed, just use the onboard graphics.
In your other thread you stated you were all up and running and was llloking for ways to check for stability.
Yeah, I didn't realize until afterwards that the RAM wasn't running at full speed.
I didn't touch the bios at all, everything was left on default settings.
It does run on the lower setting of 1333MHz without a problem. There just may be a little element of confusion here so I will clarify. The system is absolutely fine apart from when I try and get the RAM working at full speed of 1600MHz.
Thanks.
Set it to 1.6v and then if it is ok, go back into the bios and lower it slightly. Just keep doing this until you find the sweet spot.
I gave it 1.6 and it still BSOD. Should I just step it up from 1.5 and see how it goes?
This is what the BIOS settings look like if it's any help. In 'DRAM CONFIGURATION' there's lots more settings. Non of them make sense to me though lol.
Also if I just put it on 1400 it's fine without changing anything else. 1600 is the issue.
I tried 1.7. Still BSOD on desktop.
XMP can only either be on Auto or have the profile selected.
Do I need to try each stick on it's own now then with just 1600 and v1.5 selected?
There's definitely nothing I need to do with relation to the timings?
Cheers
Ok guys, so I tried each stick on its own.
The first stick I tried gave BSOD with 1600Mhz.
So I took it out, tried the other stick on its own and that one works fine at 1600MHz, no immediate BSOD.
What do I need to do in order to totally remove the motherboard from being the suspect? Try the working stick of RAM in the other RAM slot aswell just to be sure?
Cheers
Slot 1 + 3 so dual channel mode works.
EDIT - Just put the one that was dodgy at first back in and left the good one out and it booted fine. I honestly have no idea what's going on or what I need to do.
