Hi guys, unfortunately i'm lost.
Last night Firefox started crashing randomly, i just assumed the install had corrupted somehow so finished what i needed to do using IE (which ran perfectly). I then settled down to watch a film.
About halfway through the film skipped and then a BSOD (first BSOD i've had in a long, long time). After that the computer requested to scan the OS drive which froze as the counter reached 1. I then attempted to skip the scan, however windows ran terribly and eventually locked up completely.
I dug out my windows disk this morning and repaired the installation which said it needed to repair the file system. This took around 30 mins and the computer now boots, however the SSD performance is TERRIBLE. If i scan my computer using security essentials it goes incredibly slow and i'm unable to launch other programmes, Firefox crashes randomly (it crashed twice while halfway through typing this). When the computer locks up the HDD activity light is on solid, after some time the computer will begin responding again.
I've performed a disk check that, while slow, gave no errors. I've never encountered anything like this so i'm lost.
SMART data if it helps:
SMART READ DATA
Revision: 10
Attributes List
1: SSD Raw Read Error Rate Normalized Rate: 92 total ECC and RAISE errors
5: SSD Retired Block Count Reserve blocks remaining: 100%
9: SSD Power-On Hours Total hours power on: 1609
12: SSD Power Cycle Count Count of power on/off cycles: 378
171: SSD Program Fail Count Total number of Flash program operation failures: 0
172: SSD Erase Fail Count Total number of Flash erase operation failures: 0
174: SSD Unexpected power loss count Total number of unexpected power loss: 45
177: SSD Wear Range Delta Delta between most-worn and least-worn Flash blocks: 0
181: SSD Program Fail Count Total number of Flash program operation failures: 0
182: SSD Erase Fail Count Total number of Flash erase operation failures: 0
187: SSD Reported Uncorrectable Errors Uncorrectable RAISE errors reported to the host for all data access: 55
194: SSD Temperature Monitoring Current: 30 High: 30 Low: 30
195: SSD ECC On-the-fly Count Normalized Rate: 107
196: SSD Reallocation Event Count Total number of reallocated Flash blocks: 0
231: SSD Life Left Approximate SSD life Remaining: 100%
241: SSD Lifetime writes from host Number of bytes written to SSD: 576 GB
242: SSD Lifetime reads from host Number of bytes read from SSD: 1408 GB
SMART READ DATA
Revision: 10
Attributes List
