BSOD when installing XP
23 Nov 2009
North Leicestershire
Asking this for my bro as he is at work.
Basically put the xp CD in and select it as first boot device it starts to load up the first menu where you select repair, install etc etc but as soon as the bar as finished it BSOD's with the error boot drive failure. Now considering we ain't even got into installing XP yet could boot drive error mean the cd drive is fubar
this is the screen it don't even get to before it BSOD's there is a screen before it reaches this one where it loads up stuff on the bottom bar.
i would say cd/drive error or maybe hard drive? does the bios see the hard drive ok? have you had any issue before, ie. was there a problem forcing you to reinstall windows?
wipe cd/re burn and try again.
Dodgy hdd
Dodgy cd drive
Whats the spec? Is it on a sata port with AHCI turned on or something?
edit: oh and if its got any OC on it, turn it off.
It's an old mobo and cpu soket 939 bios see's the HDD's fine and the CD drive. The HDD is set to native IDE mode and not achi
the motherboard in question is http://www.gigabyte.com/products/product-page.aspx?pid=1939#ov
Dodgy hdd
Dodgy cd drive
No overclock it's all at stock and the rest is as above, i thought with it failing before it even starts installing anything that it could be the CD drive which is failing or something wrong with the disc.
Disable anything you can in the BIOS, sound, ethernet, serial port. Once XP has installed, re-enable them
are you sure components/cables are good? has the machine worked recently and you just wanted to fresh install to clean it up, or has it been sat for a while?
thinking condensation on the lens cant help
still waiting to get a cd drive chaps its weird mobo sees the hard drive i have the cd drive connected via ide to master and the hard drive is connected by sata now i think i can rule out hard drive due to the following what do you think.
my old 40 gig hard drive already has xp installed on it but i just wanted a bigger hard drive and got one from forums on here .
put in new hard drive boot from cd and put in xp disc loads the drivers then when it says starting windows it fails with bsod.
i swap hard drives over and try again with the older hard drive i know is working and it does exactley the same.
i set in the bios to boot from hard drive with the old hard drive in and it boots into windows fine.
also i put the xp disc in the drive after booted into windows and it shows as blank cd which it shouldnt should it , it should boot me to a repair thing
it should have lots of files on it, would suspect faulty drive or disc. have you tried a disc other than windows? does that show up in windows?
