- 24 Jun 2003
My setup is as per my Signature
All has been 100% fine since building it in May this year , with maybe the very very very odd crash prob like 3-4 times in that period.
However the last week it has crashed like around 30 times , so today i had enough and started to do some MEMORY tests.
The memory is Corsair Vengeance DDR3 low profile 2 x 4gb 1600mhz
the 2 sticks are located in the beige slots A2 & B2 as per the book np
within 3 secs of running memtest i had 1000's of errors , and within less than half a pass of the full tests i had 250k + of errors
After several tests with testing the sticks individually one is doing a full pass with no errors in slot A2 and the other is well lets just say giving me 1000's or errors when in the same slot A2.
So i take it 1 stick is borked ?
the good stick is currently in in the pc atm and is running Prime 95
With cpu Z my cpu is running @ 4013.59MHZ with a multi of 40 with the Bus speed 100.3Mhz ( as i lowered the Milti yesterday to see if the bsods were cpu related. )
BUT on the memory tab of CPUZ it says Dram Frequency 535.2 with the FSB : DRAM ratio @ 1:4 with latency or 9.9.9.24 Is that right or is ram being underclocked ?
I need the PC , so i think ill order another 2 sticks of the same Ram ( i take it oc still sells them ? ) and rma the 1st set ,which will result me in running 4 x 4 gb sticks once all is resolved ( is that a good or bad plan ? )
Just checked ocuk and the are still selling the 2 x 4 gig sticks ok , but they are also selling 2 x 8gig sticks as well in the same memory
http://www.overclockers.co.uk/showproduct.php?prodid=MY-307-CS&groupid=701&catid=8&subcat=1390
http://www.overclockers.co.uk/showproduct.php?prodid=MY-347-CS&groupid=701&catid=8&subcat=1390
