tolien said:A better option (depending on your perspective) might be replacing the DG834 with a router that'll let you either a) fiddle with the target SNR margin or b) cap the maximum sync rate.
The end effect's the same, you get 1Mbps down as before, but you also get the 448kbps upload rate.
Indeed - the Voyager 205 that I have lets you do this, and capping my sync rate solved my problems. The trouble is that I fixed it after I'd asked them to regrade me to a fixed 1Mb speed... meaning I have the crap 256k upload for now :/ I will be changing back to MAX when I can (ie. when F2S pull their finger out)
As for the OP, I would be surprised if you could get much more than a stable 1Mb out of your line, with your line attenuation. What you can sync at is irrelevant - I synced at up to 3000kbps and achieved 2.4Mbps download speeds at one point. But my highest 24/7 stable speed without errors is 1Mb.
, but I stay connected at that sync). I'd say from my experience of my awful line you should be able to get 2mbit from the connection
