Hey guys...im trying to fix a problem for a friend but no ideas as to what to try next.
He's on bt broadband with a BT Voyager 220 router...this is a replacment router as BT told him the first one was faulty.
Ive connected all the router up fine and its connected via the ethernet not USB.
I was told the routers ip to configure it was 192.168.1.1 ....when i put this in to setup the router it does nothing and the spinning vista timer just keeps spinning round as though it cant connect.
Ive tried ipconfig and the default gateway is blank which is probably the problem as to why i cant connect to the router.
As anyone any ideas as to what i can try?...As im stuck as to what to try next.
Thanks
Thanks
