I googled this and I'm failry sure the answer is no but its worth a double check!!
Just wanted to know can I take out a BTX mobo and stick in an ATX or will it require tapping a new thread into the case?
I have a Dell E520 case right now and to be honest its possibly the best part of this system, I don't really want to splash out on a new case and not really in a modding mood (but thats always a possibility if one will fit).
But this PC wont even run the sims 2 smoothly and it seems the cheapest CPU upgrade i can get is about £120 for a dual core intel, if I can do it i'll just get a new mobo and an AMD X2 7750+ Black ED or similar, anything should run my games better than this cruddy Intel Celron D poop!
So yeah if you can help me out here I'll give you cookies!
Cookies are subject to availability, credit check may be required before cookies are handed out, terms and conditions apply. see the back of your screen for more details.
might be worth buying one new i think they are around £120
