You can attach a bubble float to one end of the leader line and the other end of the float to your main line with a couple of feet leader.
This allows the float to bob on the surface with the leader under the water. This also requires a weight between the float and leader to sink the hook/bait.
I've seen people using now float just a weight and let the weight sink to the bottom while the bait floats above it.
Which do you use?
Any other tips ?
Which do you use?
Any other tips ?
