Hi Guys
I wanted some advice on building a budget gaming rig for around £500 (can probably stretch to £600)
I have a converted Apple PowerMac G4 case that I modified to take an mATX build a few years back, and I always planned on building a Hackintosh to go inside, but ended up just buying an actual Mac instead. I wanted to use the chassis for a casual gaming rig, as I put a lot of time and effort into the case, and I think it would make an awesome little rig!
Here's a picture of it for those interested:
So here are my requirements:
£500-600 max budget
Motherboard has to be mATX to fit in the case.
16GB of RAM
Would like an M.2 SSD (1TB preferably)
I'm running an ultra wide monitor, so will have to be able to comfortably game at 3840 x 1600 60fps
I would like a semi modular or fully modular power supply, just because I might need to get longer cables for certain things depending on where I choose to mount the PSU.
I was thinking about a GTX 1070 or 1070ti for graphics, as they are a decent price on the second hand market, but if there's something that would better bang for the buck, please say![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
I was probably going to go for a Noctua air cooler rather than water-cooled, something like a NH-U9S or NH-C14S due to case height restrictions.
I'm not going to be a hard core gamer with it, mostly a casual gamer. Probably playing things like GTA5, Forza Horizon 4 and any future releases that take my fancy. Also enjoy playing higher demanding emulators like Dolphin and PCSX2, and some not so taxing games like Parkitect and Oddworld: New 'n' Tasty.
It's been a while since I last built a PC, and my last one was a higher budget i7 4930k build, so I'm a bit out of touch with the latest PC parts.
Please tell me if my budget is unrealistic what what I'm after!![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Thank you in advance!
Have a great day everyone, and stay safe![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
![3IE2uIhS_o.jpg](https://images.imgbox.com/a2/ee/3IE2uIhS_o.jpg)
£500-600 max budget
16GB of RAM
