Budget Core 2 Duo Help
Permabanned
8 Jul 2006
Google Earth
Hi. First time posting on the forums here.
Really need help buying some components for a mATX (Small Form Factor) Computer.
So far it is planned as:
  • CP-126-IN Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail (CP-126-IN) 1
  • MB-004-AK Asrock Conroe945G-DVI (Socket 775) PCI-Express DDR2 Motherboard (MB-004-AK) 1
  • MY-083-CR Crucial 1GB (2x512MB) DDR2 PC2-5300C5 Dual Channel Kit (CT2KIT6464AA667) (MY-083-CR) 1
  • CA-076-LL Lian-Li PC-V300 Aluminum Micro ATX Mini Tower Case - Silver (CA-076-LL) 1
Which comes to £345.36 Inc VAT
I already have at home from my old pc:
  • 256mb X800 GTO2 (Unlocked pipes etc) ATI PCI-EXPRESS GFX CARD
  • Two Seagate **IDE** Hard Drives 160gb and 40gb -- Will these work on an Intel board?
  • My normal ATX PSU (Akasa PAXPOWER sommat or other - it glows blue :P so which ever that is lol)
  • 21" Widescreen and all keyboard etc
Will a normal ATX PSU fit in the Lian Li case? As will everythin else ?
Also will the old IDE hard drives i have work on the motherboard - i think it has One IDE connector...so will that mean I'll have to use Just my 160gb hard drive and a DVD drive at the same time - because I think you can connect 2 devices to obe IDE line?
Thanks for any help
I dont need a mega powerful pc, but I need a SFF one so thought Id get a Core Duo. I only play a couple MMORPGs and watch anime :)
Are you going to be overclocking?
If so, swap the motherboard for the Asus P5B-VM. The Asrock has very restricted Vcore options, and as such is a poor overclocker.
THe PSU will fit fine, AFAIK the V300 takes normal ATX PSUs without a sweat.
One IDE connector = 2 IDE devices. Maybe the other could be used in an external box? Otherwise you're going to need a PCI controller card to get all 3 in there.
Finally, it might be worth getting 2GB RAM, memory has got pretty cheap and it should make quite a difference in the long run.
