Hello,
You've recently helped me spec a budget machine for a friends' parents, but a few months have passed so I'm looking to double check my options.
Original thread
Here's my current thoughts:
There's a couple more PSUs below which look good but given there's no requirement for a GPU I figure it's better going for Gold (lower watts) versus Bronze (more watts) i.e.
From what I can tell the OEM for the XFX is a Seasonic Eco Plus series, and the OEM for the EVGA is a Super Flower.
Is the above mobo worth the extra over the cheaper MSIs?
CPU is out of stock - does anyone know if this is common of late for the G4560? Any ideas if stock is likely to incoming? If not what's the next best option? I don't really want to suggest a Celeron so the next in stock Intel option would be:
Or do we go for AMD?
I don't know whether to go for 2 x 4GB RAM sticks, or 1 x 8GB and get a quicker speed too?
Could get the M.2 version but easy way to sayve £4 I thought!
Final bits and bobs:
Thank you!
Original thread
- 1 x EVGA 450BT 450W 80 Plus Bronze Power Supply= £37.99
- 1 x XFX XT Series 500W 80 Plus Bronze Power Supply= £42.95
- 1 x MSI B250M-Pro VH Intel B250 (Socket 1151) DDR4 Micro-ATX Motherboard= £54.95
- 1 x MSI B250M Pro-VD Intel B250 (Socket 1151) DDR4 Micro-ATX Motherboard= £58.99
- 1 x MSI B250M Pro-VDH Intel B250 (Socket 1151) DDR4 Micro-ATX Motherboard= £59.99
- 1 x Kingston Fury Black 8GB (1x8GB) DDR4 PC4-21300C16 2666MHz Single Channel Module (HX426C16FB2/8)= £89.99
- 1 x Team Group Vulcan T-Force 8GB (2x4GB) DDR4 PC4-19200C14 2400MHz Dual Channel Kit - Grey (TLGD48G2400= £89.99
- 1 x Asus PCE-N10 Network Adapter 150Mbps - PCI Express= £9.95
- 1 x Asus 24x DVD±RW DRW-24D5MT SATA ReWriter - Black (Retail)= £13.99
- 1 x Kolink KLM-001 Micro-ATX Case - Black= £22.99
- 1 x Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)= £94.99
Thank you!
