I read a review that the Huawei Ascend G300 is awful on battery life, anybody confirm this?
it's actually better than a nexus 4, so long as it is running updated firmware (radio) and the newest version of CM from modaco
This is for Mrs Dimple and I don't want to mod it.
So you wouldn't agree with this review of the battery - www.disturbinthepeace.co.uk/pics3/g300.pdf
why don't you want to mod it?
I've just noticed this.
I'm not arguing but can you justify this?
it's a single core phone, nexus 4 has 4 cores.
look at the battery sizes and it's a bit like comparing 2 cars.
one has a 1 litre engine with a 15 litre capacity tank the other a 4 litre engine with a 21 litre capacity tank. which do you expect to last longer?
if you do not use the phone (idle engine), then the nexus 4 will last longer, but if you use the phone a lot (full throttle) then the g300 will last longer.
nexus 4 lasts me 10-12 hours, g300 when custom rom'd lasted 2 days.
also with the g300 it really need a custom rom the stock software is really poor, it's slow, i have owned it and it is so much better with cm on it
I'm perosnally just going to get her a Nexus4 8GB as shes give me £150 and I expect she will find it to be faster then her PC.
It's not as simple as that; the SoC in Nexus 4 is 28nm versus the 45nm SoC in the G330; it uses less energy to do the same work. Also, because it is more efficient and faster it'll do the work faster and have the cores idle faster. Furthermore, the cores aren't always firing so if only 1 or 2 is needed then the rest are offline; it doesn't always bring 4 cores online everything. So yes, if it was a case of just a binary switch from idle to 4 cores (not only that but at full clockspeeds) then your comparison up there makes sense but unfortunately that isn't the case here.it's a single core phone, nexus 4 has 4 cores.
Where are you getting a £150 N4 from?
Should have been clear I'm just going to add the difference myself as I feel its worth it. My aunt tends to keep a phone for 3 years or so but the SF2 was just such a bad phone that she can't take it anymore.
