It gives you the option in the bottom left cornerBoomAM said:Its a resolution thing.
Its got to be at 4:3 resolutions iirc for it to work fine..
How do i 'Build Deck', stuck on New07 because of it.![]()
my badHxc said:....Thats new13.
I know that!mctiny said:It gives you the option in the bottom left corner![]()
Ah.markyp23 said:You press that and then the lines you lay with that pressed will be track.
Press it again to get back to lay support lines again.
bringerofdecay said:course, if you load up the game, and select 'load level' (pick the level you want (ofc >.<)) and then press alt+f4, or ctrl+f4 you can choose how much budget you can have and how heavy the train is
i made my computer lag by copying and pasting over 1million sticks![]()
Mp4 said:I find the mouse is buggy for me in this game :/
thenormalman said:When building the bridge, click on 'build deck' to highlight it, then draw the lines which you want the train to go over.
