- 3 Feb 2007
- Birmingham
It's definitely time to upgrade my Core 2 Duo PC; it's so pathetically slow, it's effectively useless to do any games programming from work on it. At work we have 1st gen core i7's; so can do a full recompile on the games we make within 10 mins.
This means that my build will require a core i7 too, as I don't want to come home for things to take longer; the hyper-threading really does make a difference. I have regular hard drives I can use until prices some down, and I also have a DVD drive & graphics card (RadeonHD 4850) that are good enough for now. I'd really like it if I could get help in speccing up the rest of the PC? Case, PSU, CPU cooler (if you think it's best), motherboard, memory etc.
The other requirement I definitely would like, alongside the core i7 2600k, is a 128gb SSD, with which I value reliability above all else! I am quite noise concious; I'd be happy to spend a few pounds here and there to help keep the noise down, but nothing extravagant! Budget... around £600 max I guess. I don't mind going over this if needed, but would need a good reason to!
Thanks!
Thanks!
