- 11 Mar 2008
Looking for a bit of advice on a new build.
So far I am planning on using the following (though with minor tweaks depending on what is actually available) when I order - I want good power, but I do want it to run as quiet as possible
My basket at Overclockers UK:
My main sticking point is whether to go for a water cooling loop - I want to give that a try but I don't really want to have to dismantle a regular GPU cooler in order to install a waterblock - so I guess part of my decision comes down to whether I can manage to get a GPU with a pre-installed waterblock. I'd be looking at the 3080 or 3080ti (though I haven't yet see any ti models with a waterblock). Are the GPUs with a waterblock installed usually good quality?
Obviously I'll probably have to work on the basis that getting such a GPU is not likely - so I'd have to assume that I'd have to go for one with a good cooler on it. In that case, is it worth doing a water loop if it's only covering the CPU? Seems at that point I might as well just stick with a AIO CPU cooler as I've done for my last couple of builds (I'd probably go for something like this https://www.overclockers.co.uk/nzxt-kraken-x73-aio-cpu-water-cooler-360mm-hs-01l-nx.html )
I guess the specifics of the build hinge on the GPU - although I can bring my current GPU over, not knowing the final option means I'm uncertain whether to commit to a proper water cooled system at all.
Also tempted by the 5950x on the daily deal today, but not sure I would ever need all those cores!
- 1 x Asus ROG Strix X570-E Gaming (AMD AM4) DDR4 X570 Chipset ATX Motherboard= £289.99
- 1 x AMD Ryzen 9 5900X Twelve Core 4.8GHz (Socket AM4) Processor - Retail= £499.99
- 1 x Crucial Ballistix RGB 32GB (2x16GB) DDR4 PC4-28800C16 3600MHz Dual Channel Kit= £188.99
- 1 x be quiet! Silent Base 802 Midi Tower Case - Black Window= £149.99
- 1 x be quiet! Straight Power 11 1000W 80 Plus Gold Modular Power Supply= £189.95
- 1 x WD Black 1TB SN850 SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS100T1X0E)= £169.99
Total: £1,502.10 (includes shipping: £13.20)
