Build an amazingly small PC!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Now you have the tools available exclusively at OcUK to build the worlds smallest LGA1155 fully fledged PC.
With the new Lian Li PC-Q05 cases and a specially designed LP motherboard and CPU cooler from Intel.
Brands you really can trust in!
Lian Li PC-Q05A Intel DH-61AG HTPC Case - Silver @ £53.99 inc VAT
The PC-Q05 is designed for the Intel DH61AG ultra thin Mini-ITX motherboard and the Intel HTS 1155LP heat sink. The chassis features intake vent input cooling air to cool the system down. This tiny case can house up to two 2.5" HDDs for extreme data storage.
- Case Type: Mini Tower Chassis
- Dimensions: (W) 284mm x (H) 47mm x (D) 307mm
- Front bezel Material: Aluminum
- Side Panel: Aluminum
- Body Material: Aluminum
- 5.25" drive bay (External): None
- 3.5" drive bay (External): None
- HDD bay: 2.5-Inch HDD x2
- Motherboard Support: Thin Mini-ITX (intel® DH-61AG)
- Maximum Compatibility: Cooler: support the Intel HTS® 1155LP
- Package Dimensions: (W)346 mm x 98(H) mm x 343(D) mm
- Gross Weight: 1.5 KG
- Power Supply: AC 150W adapter (not include)
Only £53.99 inc VAT.
PRE-ORDER NOW
Lian Li PC-Q05B Intel DH-61AG HTPC Case - Black @ £53.99 inc VAT
PRE-ORDER NOW
Intel DH61AG Intel H61 (Socket 1155) DDR3 Mini ITX Motherboard @ £99.98 inc VAT
The Intel® Desktop Board DH61AG powered by the 2nd generation Intel® Core™ processors in the LGA1155 package offers Intel® HD Graphics with best-in-class media processing features in an innovative low z-height, thin Mini-ITX form factor. Fully compatible with low height components such as SO-DIMMs and full- and half-length PCI Express* mini-cards, the DH61AG also supports premium features such as SuperSpeed USB 3, eSATA, and Hi Current/fast charging USB 2.0 ports. Full display output support with HDMI* and DVI-I is complemented by flexible eDP or LVDS flat panel display support. Combination of low height components, premium features, and an external power supply make the DH61AG the perfect solution for high performance AIO systems, tiny FF systems, and home theater PC systems.
Features
Audio Channels 7.1
Product Type Desktop Motherboard
Manufacturer Part Number BLKDH61AG
Manufacturer Website Address www.intel.com
Manufacturer Intel Corporation
Product Model DH61AG
Product Name DH61AG Desktop Motherboard
Brand Name Intel
Number of Total Expansion Slots 3
PCI Express Standard PCI Express 2.0
Total Number of PCI Express Slots 3
Maximum Memory 16 GB
Memory Technology DDR3 SDRAM
Number of Memory Slots 2
Memory Form Factor SoDIMM
Package Contents
1 x DH61AG Desktop Motherboard
1 x Back Panel DC Jack Cover
2 x Cable, Serial ATA, Latching, L-Shaped
1 x Cable, SATA to Power & data for Slimline Drives (Y-cable)
1x DVD, Express Installer
1 x Configuration Label
1 x I/O Shield - Full Height
1 x I/O Shield - Half Height
1 x Quick Reference Guide
Software CD
Green Compliance Certificate/Authority Energy Star
China RoHS
Green Compliant Yes
Gigabit Ethernet Yes
Form Factor Mini ITX
Width 6.7"
Processor Supported
Core i5
Core i3
Core i7
Pentium Dual-core
Celeron Dual-Core
Xeon
Depth 6.7"
Number of SATA Interfaces 3
Total Processor Supported 1
Processor Socket Socket H2 LGA-1155
Processor Technology Turbo Boost Technology
Hyper-Threading Technology
64-bit Processing Yes
Chipset Manufacturer Intel
Chipset Model H61 Express
Onboard Video No
Controller Type Serial ATA/300
RAID Supported No
eSATA Yes
HDMI Yes
DVI Yes
Number of Network (RJ-45) Ports 1
Network (RJ-45) Yes
Total Number of USB Ports 4
Number of USB 3.0 Ports 2
Number of eSATA Ports 1
Total Number of Onboard USB Ports 8
Number of Onboard USB 2.0 Ports 8
Only £99.98 inc VAT.
ORDER NOW
Intel Thermal Solution HTS1155 LP CPU Cooler (Socket 1155) @ £19.99 inc VAT
As desktop form factors evolve with an emphasis on thinness (like All-in-Ones and SFF PCs), cooling solutions needed to evolve to support local integration. The Thin Mini-ITX platform is designed for such applications, and Intel’s HTS1155LP is a core building block that delivers exceptional performance and enables the evolution of the desktop.
- Radiator Dimensions: 77 x 77 x 26 mm
- Heat SinkWeight: 264 grams
- Blower Dimensions: 80x 80 x 22 mm
- Blower Weight: 54 grams
- Blower Cable Length: 20.5 inches or 521 mm
- FanSpeed: 1180 –3380 RPM
- Thermal Interface Material (TIM): TC-1996
Only £19.99 inc VAT.
ORDER NOW
This is VERY interesting as I want to build an appliance from socket 1155 kit.
Questions:
Board lists 3 pci-e expansion slots....is that true. If so does it use a riser? If not is the listing wrong? If the board supports at least 1 PCI-E expansion card on what looks like a single 4x slot on the motherboard, does the posted lian li case support an expansion card? Seems not?
Power - case says ac adapter is not included, does the motherboard package contain one? If neither do are you stocking compatible units?
Cooler - Any chance of some temp testing and, more importantly, how much noise?
Intel's site for this board (http://www.intel.com/content/www/us/en/motherboards/desktop-motherboards/desktop-board-dh61ag.html) lists:
1x full size Mini PCI-e
1x half size Mini PCI-e
1x PCI-e 2.0 x4
So the description looks correct, but they're not regular desktop ports, I think they're more what you find on laptops.
From the picture, looks like the PCI-e 2.0 x4 is on the far right of the board (as the picture shows above). The half height slot is just to the left of that, behind the audio jacks and next to the heat sink and pointing towards the first slot. The final slot (the full size mini) looks to be directly behind the DVI port and pointing towards it.
So if I put an i3 or something in I would be able to use it as a smart tv box?
Epic :)
Edit: can this take laptop graphics cards?
