- 4 Oct 2012
total cost is 1572. what do you think of this?
thanks for reply. Why would you go with the gigabyte board for? What case would you recomend instaedNot a-lot.
I would get an i7 and a 770 with your budget personally, and then overclock them both. But the i5 and 780 combination works fine too.
I would get a 256GB SSD rather than a 120GB as you will find the 120 filling up quite fast.
I wouldnt get an MSI motherboard, I would get a Gigabyte Z87X-D3H.
I wouldnt touch a Phantom case with a barge pole because it may be £110 but it looks like it should cost half that. I would get something with a far better metal construction if you want to spend that much on a case.
The PSU is alright, but I wouldn't get that model, I would plump for a 750W 80+ Silver XFX XXX like mine, A Corsair TX750 or a Seasonic.
You would also benefit hugely from getting aftermarket cooling as you wont be overclocking that CPU without it, and it will run quite hot even at stock clocks.
All in stock bits,
This is what acme was sort of imagining.
YOUR BASKET
1 x KFA2 Geforce GTX 770 EX OC 2048MB GDDR5 PCI-Express Graphics Card (77XPH6DV6KXZ) with FREE GPU Keyring £339.95
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £275.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £134.99
1 x Gigabyte Z87X-D3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £131.99
1 x Corsair Enthusiast Series TX750M High Performance 750W '80 Plus Bronze' Modular Power Supply (CP-9020040-UK) £99.98
1 x Corsair Vengeance C70 Midi Tower Gaming Case - GunMetal Black £94.99
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £83.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £74.99
1 x SteelSeries 6G v2 Mechanical Gaming Keyboard (64226) - Black Switch £74.99
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual CHannel Kit (PV38G213C1K) £65.99
1 x Alpenföhn K2 Mount Doom CPU Cooler £59.99
1 x Steelseries Kinzu V2 3200 DPI Rubberised Black Gaming Mouse (62022) £39.95
Total : £1,499.20 (includes shipping : £17.85).
You nailed it Doomedspeed.
It is indeed a stonking rig.![]()
You could get an 850W PSU I suppose, just so that it leaves the possibility of adding a second GTX770 in the future as well as allowing overclocking headroom for both 770's and the i7.
A 750 would be fine for the i7 & 770 though.![]()
The 750w PSU will be for SLI and overclocking the i7.
