Build Build Build
8 Sep 2007
Built my pc!!
Yup, FINALLY getting to build my computer, collected the parts for a while (hope they work :rolleyes:) and finally building, and of course, i will include pics!!
Ive got one question though, my case front panel has a AC97 and an HD Audio plug, which one do i use?
Heres the pics of progress so far
looking good - keep it up
where is your psu?
i would consider crossfiring with the psu and gfx you have
also the x38 board would do it justice
dont bother with the sound card and get another 4870 ;)
psu is going in in a minute, corsair 750, this was the front panel sound connector, i wasnt sure what one to use, if any :P
and cheers, yer, im thinking about crossfire down the line
but you have to go crossfire
it makes sense lol!
keep those cables tidy though dude - you will get some grief of the boys on here if they see messy internals
would be interesting to see some benchies off you once you get the rig up and running!
how long ago did you buy the q6600? rumour has it that the new ones dont clock well?
i got my q6600 on saturday, came today but that doesnt necessarily mean its new or old i guess
im installing my optical drive and its SATA, never used that before when installing, same for my HD, I can see where im plugging them in but my Optical drive has a spare socket and the other socket is filled, then on my mobo, i have 6 sata ports to fill, where do i put them? its like a small L and a big L and the small L is filled
infact one will be the sata power cable
I love to see a new build going up, hope you enjoy the PC!
Re: front panel connections, use the HD Audio cable.
Stick your RAM in alternate slots as well to take advantage of dual channel.
installing the OS atm, and it came up loading files and then went to a turquoise vista style background, the mouse icon has appeared but nothing else is coming up, is this normal, do i just have to wait a while?
edit: thats it just come up now lol but its taking its time
cool, cheers
thats me all sorted by the looks of it, about to install some games and try out this 4870, im so hyped!
thanks to everyone in my spec thread months ago aswell who helped me out! and the guys in the motherboard section who helped me out
what program shall i get for watching the blu ray films?
