Hi - I'm building only my second system ever and actually my first build in 15 years. I put together a list of things I need to do so I don't get overwhelmed when all the bits arrive. I'm NEVER this organised but I may be without a computer before the build happens so Googling for info will be on my phone and I thought I'd do some planning for once.
Am I missing anything and is anything in the wrong order?
Prep
Build
OS
Peripherals
Testing
Prep
- Prep Win 11 install, memtest64 and BIOS update USB keys
Build
- Remove case panels and install correct standoffs and i/o plate
- Prep motherboard
- Install CPU and cooler, connect cooler power cable
- Install mem in to slots A2 and B2 (confirm position with FIRST label on motherboard)
- Install NVME drive
- Install motherboard
- Connect motherboard to front panel header and case ARGB controller
- Connect fans to ARGB controller or motherboard - need to find out where to connect fans
- Install PSU and connect to motherboard ATX and CPU connectors
- Install 5700 XT GPU
- Remove two slot covers
- Connect to PSU with 2 PCI-E cables (clip will be on top)
- Insert BIOS update USB key, reboot on and enter BIOS settings
- Set boot sequence to be USB first then NVME second
- Turn off auto-optimisation settings for stability during Windows install
- Update BIOS by selecting m-flash
OS
- Install Windows via USB drive (pull drive on reboot when screen goes black after file copy)
- Windows update
- Install AMD graphics driver amd.com/en/support
- Set refresh rate via driver settings in control panel or Windows display settings
- Install motherboard software and set up
- Reboot and enter BIOS menu
- Turn on Expo and reboot in to BIOS menu to check POST and train RAM
- Check RAM is running at 3600
- Turn on BIOS optimisation settings
Peripherals
- Connect Magic keyboard and install Razer mouse software
- Plug in Steelseries USB headphone receiver and connect them up
- Connect bluetooth soundbar
Testing
- Run realbench for 16 hours
- memtest if not done pre Windows install
