Hello all,
I would like some help to select parts for my girlfriend's pc. On top of the usual activities, she also does sound editing and entry level video editing. The initial budget is on the order of 1000 euro. We are located in Belgium.
I am not experienced in video editing requirements, but I figured out that for entry level what you need is a reasonable processor, enough ram and some good drive on which you can write stuff fast enough.
A beefy GPU is not required, it just accelerates the rendering of some effects. If this is right, I want to aim for a processor with integrated graphic card. Given the budget, probably at the moment intel is the better choice, even with those new AMD processors with integrated GPU.
As an initial guess, this is what I selected. If you see something terribly wrong or adjustments you think might be good, just suggest, the post is for that.
Component
CPU Intel i5 11400 180 euro
Motherboard Asus Prime B560 Plus 130 euro
RAM Corsair LPX 16 Gb 3200 Mhz 90 euro
Storage 1 (OS,Programs, Writing) Samsung 970 evo plus 500GB 85 euro
Storage 2 (Actual Storing) Seagate Barracuda 2TB 60 euro
CPU cooler Cooler Master Hyper 212 35 euro
PSU Corsair RMx 550W 80 euro
Case Fractal design Meshify C 80 euro
WIFI-Bluetooth Adapter Tp-Link Archer TX3000E 45 euro
Windows Windows 145 euro
Screen + Mouse + God Knows What TBD Estimated 150 euro
TOTAL 1080 euro
Some notes or questions:
Lorenzo
Component
TOTAL 1080 euro
- the 550W PSU is a bit overkill, but at one point we might add a thunderbolt card. Also, I can't find a good quality modular PSUs below 550W.
- Is the CPU reasonable? Should I try to squeeze 2 additional cores ? We don't have to render Avengers End Game 2 in 16K. It's a side activity required in her musician career.
- Does anybody have an estimate of the RAM usage per core when rendering? For example, in CFD Simulations it's 2-4 Gb per core, but rendering is not CFD. I think 16 Gb is enough, but I want to make sure
- Cooler Choice? Seems budget but I saw good reviews. Will it keep cool enough even when boosting with 6 cores? That 65 watt TDP is a lie.
- Where would you cut price? Where would you spend more?
Lorenzo
