I have full system bits arriving from OcUK tomorrow but I haven't built a PC for years.
I'm pretty sure I'll be OK with the build itself ie putting the MB in etc but not sure after that.
It's a 3950X build on a Asus MB, thiss but with the WiFi board:
https://www.overclockers.co.uk/8-pa...ro-corsair-64gb-3600mhz-bundle-bu-01v-am.html
any tips to get started..
I have a USB stick with Windows 10 on, do I have to go into the BIOS first and if so what do I choose?
Is there any settings in the BIOS I should be looking out for or is it pretty much plug and play (or prey in my case).
Any help in advance appreciated so I don't pull my hair out when I get around to the build.
Thanks![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
Thanks
