- 27 Jul 2006
- Huddersfield
Ok ive got the following new build on my desk
Intel Core i5 760 2.80GHz (Lynnfield) (Socket LGA1156) -
Gigabyte GA-P55-USB3 Intel P55 (Socket 1156) DDR3 Motherboard
Microsoft Windows 7 Home Premium 64-Bit - OEM (GFC-00599)
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ)
Coolermaster Elite 430 Windowed Case - Black
Sony Optiarc DRU-870S 24x DVD±RW SATA ReWriter (Black) - Retail
and a OCZ ModXstream-pro 700w psu
When i turn it on i got a contiuse short beep which state there is a power issue.
From the PSU i have 3 built in cables, one 8 pin, i know where that goes, a 24pin, this is spit into a 20 and 4 pin that stick together into the atx power thingy, and then a 4 pin with yellow and black coloured cables, i cant see where this should go (and i dont think it needs to.
Can anyone suggest what may be wrong?
Thanks in advance.
Thanks in advance.
