- 12 Feb 2009
- UK
>>>>Finished Pics here<<<
Introduction.
Hi everyone,
A few years ago I was into spending lots of my money on Custom PCs which meant I had a few WC builds in a short space of time but things in life came up which meant I had to sell up and go with something alittle more basic. Anyway now I’ve got abit more time and money I want to get a custom looped build again. Parts below have all been ordered except the hard tubing as may go with PETG and Ram as I killed my last set trying to remove the heat spreaders.
Main Components:
- CPU: Core i7 4790k (Supposed to do 5GHz but we will see. Also ordered a cheap CPU to practice delidding on before I risk doing this one.)
- Motherboard: MSI Z97M Gaming.
- Graphics Card: 2x GTX780ti
- Memory: 16GB 1600Mhz.
- Storage: Samsung 840 Evo 250GB.
- Power Supply: Corsair Pro AX860 with Full Custom Cable Sleeving by PexonPcs.
- Chassis: Phantek Evolv mATX in Gloss White.
Cooling:
- CPU Block: EK Supremacy Evo Full Nickel.
- GPU Block: 2x EK FC780 Nickel and Acetal.
- RAM Block: EK Monarch X4 Clean CSQ Acetal and Nickel.
- Pump: EK-D5 PWM with EK-D5 Cover Kit Nickel and Acetal.
- Res: EK-D5 X-RES 100 CSQ Acetal.
- Radiator: 2x XSPC AX240 White.
- Fans: 4x Noiseblocker NB-eLoop 1x Alpenföhn 140mm Wing Boost 2 Plus PWM Fan Red.
- Hardline Fittings: PrimoChill Revolver 13/10mm Diamond Black.
- Soft Tubing Fittings: EK-ACF Fitting 12/16mm Black.
- Fitting adaptors: Mix of Matt black Bitspower and Barrow fittings.
- Tubing: Mix of Black PrimoChill LRT in Black and Hardline tubing undecided yet.
Tour of the case.
First thing I did was went about fitting both radiators in the case. My aim with the radiators is to have none of the fans or fittings on show to give a clean look to the build. The one in the roof was simple, just screw it in with the outlets facing up so they are out of sight. I should just be able to squeeze some 90 degree non rotary Bitspower fittings in here but this is at the moment un tested as waiting for fittings.
The one in the front required cutting the false floor of the case at the front as the XSPC AX rads are too wide. Having it fitted like this means the outlets are again hidden in the lower compartment.
I then cut the little removable door down and refitted this against the rad to hide anything below. It’s a very tight fit but looks neat.
The fan Ive chosen for the exhaust is the Alpenföhn 140mm Wing Boost 2. Ive not used these before but seems to be highly regarded and is a change from the normal corsair fans.
This is where the build is currently. Should be able to get a few more updates as parts roll in through the post. Thanks.
Hopefully vti can find it for me and save me abit of cash.
