Over the past two weeks I've been sorting out my build, looking at reviews, getting Spec Checks etc. Thanks to a number of members here, I now have all my components (SSD and RAM on way)..
To be honest I have little idea what I'm doing, as I haven't found many Lian Li X500 builds... I have been checking out some guides though..
I think I almost know what I'm doing with everything bar the fans.. The case has a controller, and I don't know which fans should be plugged into the motherboard or PSU..
Here are some pictures to show what I mean....
(above) These come from the fan controller
(above) There are four fans, I take it they go straight into the power? Fan controller somehow changes their speed although they don't have a direct connection?
(above) Fan on heatsink. Firsty, how do I know if the fans facing the right direction?! (till I switch it on - there aren't arrows on it like I've seen on others). Secondly - Where does the connector plug in... It fits in system fan but not cpu fan...
Thanks for any help!
Edit: Sorry for huge image! Changed..
