[Build Log] MODZERO FORTY - HEX GEAR R40
They're coming..
J.
UPDATE 6.0 - THE FINALE (ISH)
It's done, for now at least. The build has been running on my desktop for a few weeks. For one reason or another I wasn't happy with the original loop, so it's seen a few revisions. I went from the Mayhems Clear flexi with Mayhems Oil Black to Primochill LRT Onyx Black with Di-Water to Tygon Neoprene with di-water + Mayhems dark red dye.
I'm no photographer but do enjoy trying. I wanted to capture the build powered on with the way I have the LEDs set up. The two white Darkside strips are run quite dim as not to over power the Klevv RAM, they also cast a great shadow over the midwall (not that you can really tell from my photos... oops).
I'm really glad I held out for the KLEVV RAM. Originally looking for the URBANE kit I really struggling to find enough stock in one place to fill all four dimms. In the end I was able to pick up the KLEVV GENUINE 4x4gb 2400mhz kit at a great price, SO glad I did. In the process I was sent some KLEVV URBANE by mistake. I'll certainly be putting that to good use soon*.
So it's finished, ish.. I'm in talks with a company that can make me two new all glass tinted side panels. If that ends up happening I'll break out the studio lights again and be sure to share.
I'm eager to get started on a new project, couple builds in the works. Hoping to reach out to possible new sponsors in the coming weeks to make them extra exciting.
This wouldn't have happened without the support of E22 and HEX GEAR, massive thankyou to those guys. Furthermore the help both Nate and Hans have provided during this process has been amazing. Thanks Guys.
J.
I love this build, so many components I have never seen used before, the tubing & ram in particular looks amazing. Stunning job mate!
Wow, I think I'm in love! Looking awesome mate, the matt black tubing really finishes it off, makes it look far more sinister :)
That's absolutely beautiful, very classy 10 thumbs up nevermind 2 :eek:
Haha, awesome, thanks.
Thanks fella, check out KLEVV all their RAM skus look great! I'm really happy with how the tubing turned out too. The neoprene has a great texture to it.
Unbelievable work, very nicely done.
Thanks, I'm looking forward to starting my next project in the new year.
Thanks, I went through a few flex tube options before arriving at the Tygon. It was actually pOPe's idea to give it a go.
J.
Whats the tubing diameter and fittings manufacturer? Its looks great. You've managed to make flexi tubing look neat.
