[Build Log] -------- "MONOCHROME" --------
20 Jul 2014
South San Francisco, CA
Welcome to my next build! This one has been kind of on the backburner for quite some time, as I've been waiting on the case. This will be a very clean promotional build for a new case from a new case manufacturer, of which I still can't disclose... yet, hence the "censored" area of the sponsor line up above.
I have the case in my possession and will show it as soon as I'm allowed (very soon) via photos and a video overview. The case itself is very clean, well made, and just oozes quality. I look forward to showing it off and doing this build with it.
Leading up to my ability to show the case I will of course, in my typical fashion, be photo-logging all of the other parts to be used in the build. This thing will be a powerhouse!
Main Components:
Motherboard: EVGA X99 Micro
CPU: Intel 5960x
Memory: G Skill DDR4 2400 32Gb
GPU: 2 x Nvidia Titan Z
PSU: EVGA 1600w G2
SSD: 3 x Intel 730 480Gb
Watercooling Components:
CPU Block: EK Supremacy Clean CSQ Nickel
GPU Blocks: 2 x EK Titan Z Nickel
Ram Blocks: EK Monarch Acetal + Nickel
Radiators: EK Coolstream PE 240mm + 360mm
Pump: UNDECIDED
Reservoir: UNDECIDED
Tube Fittings: Rocket Science 1/2 inch (12.7mm) tube fittings
Other Fittings (Misc): UNDECIDED
Tubing: Chrome/Nickel plated 1/2 inch (12.7mm) copper
Coolant: UNDECIDED
Other Components:
Fans: UNDECIDED
Cables: Ensourced Custom Sleeved Cables
Lighting: Darkside Connect LED strips
Can't wait for photos and see whats in store :-)
Not too sure on the led strips thou will have to see how it pans out.
Damn James, hasn't the paint only just dried on your last build? lol
Looking fwd to more of your quality work!
^ Sorry but you need to resize those images.
Unless otherwise agreed by the moderation team, images must be no wider than 1280 pixels wide.
Spoiler tags should not be used in any build log. Do not put your pictures in spoiler tags. nobody wants to click every single picture individually. Unsurprisingly, they are in your thread to see your work.
I'll be the first to say, how'd they taste ya mad man. Copper tubing? Interesting build not seen that before, hope for more in the future.
looking forward to this one.
and I don't know if you've noticed, but you appear to have dropped a bit of sauce on one of them. not much though.
You are one busy guy! can't wait to see the case!?!? I've got an idea of what it may be.. can I post my guess? I guess wE'll Know soon enough.. haha. As always, looking forward to more.
J.
Will the copper tubing be nickel plated? This is going to be one mean build :P
Yes sir :)
Here's the G Skill DDR4 I'm going to use. I opted for the "value" labeled sticks so I didn't have to mess around with removing the heatsinks. I then mounted the amazing looking EK Monarch heatsinks which will allow me to attach the EK Monarch Ram waterblocks later. These EK heatsinks are seriously really nice quality, the machine work is top notch, plus the design in usual EK fashion is clean and modern.
