- 26 Dec 2013
- 404 Not Found
[Build Log] - Project Big2Small (Prodigy ITX Build)
So, after building my Corsair Carbide 540 in the summer of last year, I decided it was looking to bulky and that was a good enough excuse to build a new PC.
The build is going to be done in stages, using some parts from my existing build while I learn about custom water cooling loops and decide on a new graphics card etc.
1 - Modification of the Bitfenix Prodigy (Side panels, front panels, relocation of power buttons etc)
2 - Installation of motherboard, PSU and basic components and create custom cables to avoid any excess cabling.
3 - A top mounted H100i I currently own will be used to cool the CPU until I learn about a custom loop and decide on which card to go with. I would prefer to go with an acrylic tubing setup rather than hoses, so as a newbie to custom loops, it's going to take some learning.
I have just started drawing out templates for new windowed panels and front panels.
The front panel is going to be 10mm thick acrylic in either black or very tinted so you can only see through it when there is a light source on behind it.
I am going to cut up the existing side panels and have some tinted side windows made up. These will be mounted using M5 bolts rather than double sides tap to get a better affect.
I will update as I go along. If you have any ideas or suggestions for my build feel free to comment.
Update 01-02-15
I've just cut the side panels using a Jigsaw.
Panels have not warped or bent from cutting. Fairly impressed with the quality of the metal work from Bitfenix. Need to clean off the remaining masking tape and sand the edges down a bit more. I was originally thinking I would have to repsray the panels, but i'm going to see if I can get away with a black marker pen and colour up the exposed edges.
Update 01-02-15
