Hi ladies & gentlemen,
I am taking my first steps into the realm of water cooling which has been prompted after seeing the vast amount of b-e-a-utiful machines on here. I am jumping in at the deep end and using acrylic tubing which I really hope I can master as I have seen many posts of people finding it difficult going through over 10ft of tubing... I have been buying parts since December and have pretty much got everything I need now (After many returns of faulty goods and being messed about by retailers...) so lets take a look
PC Components:
CPU: i5 3570K
Motherboard: MSI Z77A-GD65
GPU: EVGA GTX 660 FTW SLI
RAM: Corsair Vengeance Low Profile (2x4GB)
HDD: Samsung 830 256GB, Seagate Barracuda (3x2TB)
Case: Phanteks Enthoo Primo
PSU: OCZ ModXStream Pro 600W
P.S All the PC Components I have used for nearly a year and due to financial constraints I could not upgrade.
Water Cooling Components:
CPU Block: EK-Supremacy - Acetal
GPU Blocks: EK-VGA Supremacy - Acetal
Pump: Alphacool VPP655
Radiators: Alphacool NexXxoS UT60 420, Alphacool NexXxoS UT60 280
Reservoir: Alphacool Cape Fuzion Core 30
Tubing: EK-HD Tube 12/16mm
Fittings: EK-HD Adapter - Black
Fans: Phanteks PH-F140SP
Coolant: Mayhems Pastel UV White, Mayhems Blue Dye
Miscellaneous:
Lighting: Phobya LED-Flexlight LowDensity (2xUV, 3xWhite)
Cables: Bitfenix Alchemy SATA (5xWhite), Gelid Solutions 24pin, 8pin, 6pin
Possible Loop Configurations:
1:
2:
Gallery:
PC Components:
CPU: i5 3570K
Miscellaneous:
1:
2:
Gallery:
Parts:
Spray Paint & Vinyl:
Cable Stitching:
Acrylic Tubing:
What i had when i started the build:
2 dusty looking GPUs:
Mayhems Pastel White and Blue dye.
M3 Dome Acorn Nut:
GPU bridge:
Kobra spraypaint:
New delivery of tubing:
Some XSPC compression fittings along side an EK-HD 12/16mm for the GPU bridge:
M3 Dome Acorn Nut:
GPU bridge:
Kobra spraypaint:
Carbon Fibre vinyl:
Front grill sprayed white, i like the contrast:
Cable Stitching:
First ever attempt at cable stitching using my own method:
Acrylic Tubing:
First attempt at pipe bending:
At the time of taking these photos i had ran out of my 2 metres of tubing and was awaiting another 3 metres. I was not very happy with the outcome as the bends were not as tidy as i would have liked, therefore i have decided to re-create each piece when the new tubing arrives:
Bending equipment:
New piece using new tubing and the new Nitrile O-Ring cord (Unlike the blue silicone tube shown in the previous photos)
GPU Backplate (Not yet fitted):
GPU bridge combing my 2 universal blocks (Previously i decided to join them together using acrylic tubing but this proved difficult and messy so i decided to go down this route):
Bending equipment:
