- 6 Jan 2013
- Rollergirl
I've never built a system before, and I want to take one on as a project. I would be grateful if you guys could help me out with a spec. I've seen a step by step guide in this section on how to do it, so I'll follow that and only ask build questions here when I am unsure.
I don't want to set a monetary budget. Instead, I want to aim for a particular system. I want a gaming system capable of running Skyrim on full graphics. I would like to leave some scope for future upgrade, ie faster graphics card, more ram etc. But initially a system that will cope with that game will be fine. Obviously, the cheaper the better but I wouldn't want to compromise too much on price if it's a big drain on performance.
There is no requirement for optical drive, although I may fit one in future. I do require wifi adapter and Ethernet port. There is no requirement for a sound card, but again I would like ability to install one in future. I don't need card readers and the like, but I would obviously need some USB ports, preferably USB 3.0.
Is this enough info to go on?
** edit - budget set at £1500 **
Currently Purchased
YOUR BASKET
1 x Corsair Professional Series HX+ 850W '80+ Gold' Modular Power Supply (CP-9020032-UK) £129.95
1 x Cooler Master CM-690 II Advanced USB3.0 Dominator Case - Black £85.99
Total : £230.04 (includes shipping : £11.75).
Currently Purchased
YOUR BASKET
That a decent 650W can actually x-fire those cards.
