skim read through the thread, has anyone mentioned about a new PSU?
Then it will fit.
Do you think the rest of the parts to the build above are a sound investment? I'm hoping to keep these for a couple of years, I will likely upgrade along the way in terms of new case/hard drives and such.
And this will absolutely run BF3 on fairly high settings on a 1680x1050 resolution without any issues?
Also, is the 2500K easy and safe to OC on air alone?
So is the 6950 not worth it? Now I'm confused.
A A4 piece of paper is 297mm along its long side.
Offer that up to it.
Am not sure what his spec is atm, but whenever I game with him I can hear budgies chirping in the background, so not sure if they are being used as some sort of power source![]()
