- 22 Mar 2006
Right, I have the Graphics Card ordered (Ordered this Baby just incase the price went up when it came instock
XFX Geforce 7900GT for £199 Delivered (Not bad
Now I need the Rest of the System
Already have a Case (Thermaltake Soprano) so just need Motherboard, PSU, Ram, Harddrive and Processor.
I want to spend in these price ranges on the parts -
PSU - £40 Max
Harddrive - £65 Max
Ram - £75 Max
Processor - £110 Max
Motherboard - £60 Max
After Reading reviews it seems MSI is one of the best to go with for Motherboards so is this ok? -
MSI K8N Neo4-F SKT939 PCI-E Dual DDR400 SATA & ATA Raid GB LAN
Then for Processor I was wanting to go with a Retail AMD 64bit CPU as I have read some stories of them OEM ones (Them ones that usually just come in the Brown Box) being faulty or not working as good as the Retail Version which also comes with quite a good cooler. So I was thinking of this -
Retail Boxed AMD Athlon 64 3200 Venice Core 512k 90nm Socket 939Pin
Sata seems to be the latest thing to go for when getting a Harddrive so I thought maybe this? -
Maxtor DiamondMax 10 SATAII 250GB 16Mb Cache Hard Disk Drive
Corsair seems good for Ram so I was thinking either this -
Corsair XMS3200 1GB (2x512MB) 400Mhz Non-ECC Matched Pair
or
Corsair Value Select 1024Mb (2x512Mb) Kit 400MHz 184Pin PC3200 CL2.5
Now for a Power Supply. I was going to go with a cheap £15 one, but worried about it dieing and taking half my system with it... so I was thinkign about these -
ThermalTake TR2 Value 470W
ThermalTake Purepower 430W PowerSupply
Any comments / help would be greatly appriciated
... Or if you know any cheaper sites let me know
Thanks
-XFX Geforce 7900GT for £199 Delivered (Not bad
)Now I need the Rest of the System
PSU - £40 Max
Harddrive - £65 Max
Ram - £75 Max
or
Thanks
