Building a supercharged Exocet
19 Mar 2012
I thought some people might be interested in my midlife crisis project....
I had an NB MX5 Sport which was the ideal basis for a quicker MX5 for a bit of B-Road and track fun, it has an LSD and bigger brakes as standard so seemed ideal for enhancing the power a little bit.
The "quicker" came about via this..
Which resulted in this...
However the rust apparent under the bonnet wasn't just surface rust and I got an advisory on the last MOT, the chassis rails are scrap. At this point i started looking at restoration costs but then stumbled across the Exocet and a silly plan was hatched with the aim of 400bhp per ton in a great handling package.
I'm hoping to pick my chassis and parts up soon though there's some work to be done before I'm really ready for it.
After a day or so on my own, having done next to no car maintenance before, I'd got this far...
I then got a mate round on Saturday for a few hours and we had a good go at the engine bay, most of the ancillaries are largely disconnected or removed and we've got the loom pulled through into the cabin.
Amazing learning curve so far, but starting to feel more confident that I/we can pull this off!
I then managed another hour after work last night.
Keeping an eye on this :)
What charger is that?
Rotrex, nice little unit, runs cooler than a normal supercharger, comes with an independent cooling and filtration system.
I think i can drop a pulley size for a bit more oomph, if the car comes in at 650kg, I'll need about 260bhp for the 400bhp per ton, might be doable.
Or go big on an engine build and see if i can run a turbo back there too for dual charged stupidity. :D
Dis gon be gud
We'll see, I've never even changed brake pads before....
I'm treating it like my first PC build, take one apart to understand it and then rebuild, it's just a little more involved.
I'm drawing diagrams of how the charger and custom ECU were built into the OEM bits and labelling up the loom as i go.
So the MX5 is the donor for the exocet? I'm interested as I've got an MX5 that's starting to become more rust than car.
Less than that really.
You basically strip and disconnect the body from the suspension and submount and then lift it off with an engine hoist.
Most people then strip the suspension etc down, rebush and powder coat, but you dont have to.
Then you bolt a pre-assembled tubular chassis to the MX5 "skate", add the body work with supplied rivets etc, run your brake / fuel lines and electrics down the tunnel, which comes as a sheet of metal to be cut to shape.
The loom you just coil up the bits you don't need and put in a tray on the bulkhead.
I'm having to remove AC, PAS and probably I'll take the ABS out too.
Hopefully having already got a Megasquirt 3 ECU i shouldn't have too many issues with doing so.
mk1 and 2 mx5, so i think you're golden, according to your signature pic...
used to have a mk3.5 and I've been itching at getting another for a weekend car, but getting a 3.5 would stop me for being able to exocet it... guess I'll watch this...
Yep mines a late NB (mk2.5).
Very interesting i'd quite like to do something like this. Looks like this retains the OEM suspension though, won't that be all wrong for a car of half the weight afterwards?
