I am thinking about building a computer case myself from wood, but is this idea crazy and shouldn’t I do it or will it be fun and work well?
Reasons why to do it:
- Fun
- Allows me to put stuff where I want it (inverted mobo, PSU/HDD’s separate)
- Wood is good for stopping noise?
Reasons not to:
- Might be too difficult (for me)
- Wood resonates?
- Will wood be bad for the components re: earthing?
This is what I thought about so far:
The PSU will be resting on foam, the harddisk will be suspended by rubberbands and the rack will be on foam also.
What is the best way to mount the fans to stop resonance?
The northbridge fan will be changed to a Zalman ZM-NB47J and will be modded to fit.
Any tips on things I can change like less fans or different positions?
- Fun
Reasons not to:
- Wood resonates?
. It wont cost much if you use faced plywood and will look as good as using timber. I'm currently designing an Ash timber front for my case that will match my speakers. The timber will cost me £30 for a piece of American Ash 260mm x 660mm x 25mm so a full case could cost quite a lot.
. I was going to make the front out of solid walnut and make it so that it can be removed. Hinges on the door for easy access and also a nice brass 5 lever drawer lock. It would have looked great but the price of the walnut was £60 the veneer was £20 and the ply and bit would have come to around £20 which made it a bit too dear as i don't even have a rig to put in it lol. I'm now just going to make an Ash front for my Eclipse62 and stain it black
