The Zalman Z11 only takes a gpu up to 290mm in length. The Gigabyte 290 card is 294mm according to the spec page on ocuk, so that probably won't fit without a bit of a struggle.
The MSI 290 card should fit fine though, as it is only 276mm long.
Either the Samsung or Kingston SSD's are good. You get watchdogs with the kingston SSD if that appeals to you. If not then the Samsung is probably slightly quicker.
