Okay fitted my psu/hdd/cd drive.
Ive now got to take my motherboard from the old case and put it into the new case. Any suggestions on what I should do? Simply unscrew, lift and place it into the new case. Should i touch the case before i touch the motherboard to clear static?
Do i also need to use standoffs? I believe the Lancool pc 62 has gold rings aka standoffs already on the case, so im guessing i just need to align the board on it and with the backpanel, then screw them not too hard into position.
Then im guessing all thats left, is to install the Graphics card, and plug everything into the mobo?
Thanks
Thanks
