Building my Computer, Noobie questions - Help Appriciated
20 Aug 2011
Ok so I ordered loads of stuff to build a computer, put it all together etc. When I try to boot my HDD from the bios it says "Reboot and select proper boot device or insert boot media in selected boot device and press a key.
I'm using "Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ)" and "Asus P8P67 LE Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION **"
Do I need an operating system to boot my HDD, I'm not really sure of what to do after I've put all the parts together.
At the minute I've got windows 7 extracting to my USB, can someobdy give me a step by step guide on how to install everything a computer needs fresh off the bat.
know with a windows 7 ISO, what do I choose on imgburn
