- 12 Sep 2012
Have fun. See you later.
Have you installed your all your mobo and Gpu drivers.
I have indeed mate.
Can't wait for a Stevo watercooling thread.
HAHA cheers guys, slight problem, when I go to system requirement labs and check a game I fail as I have no "dedicated video ram" Im assuming this is because the intergrated graphics are on but I dont know how to change them to my graphics card, any ideas?
You should have a setting in the Bios. Select PCIE as your main graphics output.
In the Bios, go to Peripherals and scroll down to Init Display First and select PEG .
That didnt work mate.
And your monitor is connected to your graphics card and not the mobo. Just checking.
Ya mate.
And the card is in the right PCIE slot. PEG should have made the PCIE 3.0 x16 slot your first graphics output.
The latest AMD driver is all you need for the Gpu. When you selected PEG earlier, you did save the settings when you exited the Bios.
Just making sure you hav`nt overlooked something.
I did, Should I also disable internal graphics?
You could try that.
Tbh, i would open a thread in the Graphics forum.
Ya it's in Pci 3.0. I only downloaded 1 driver update ( the latest) do I need to download them all?
