Hi, new here.
I am going to be building my first system. This system will be for work only, no gaming, hopefully. The work I will be doing is the general essays and such, but also using photoshop cs2 and other programs within the CS2. I will also try to learn the 3D apps, like 3DS Max.
From what i gather I only need to focus on my ram and processor speed. And a little on graphics if I want to do modeling.
I do have a question however, they say you need faster clock speeds for ram if you want to overclock, would this mean OC'ing the ram, or generaloverclocking (new to OC'ing).
I believe everything is focused on overclocking. I did have to reduce the ram to 1gb sadly, but I will be upgrading soon.
Another reason for this system is its great potential to upgrade, and also it meets the Vista requirements.
Oh btw, I wont be OCing my video card (unless someone suggest to).
NEC MultiSync® LCD20WGX2 20.1" Widescreen LCD Monitor
£370.11 inc VAT
Actually could you point me to some DDR2 RAM that is about the same price? 2GB prefer, but 1gb is fine (upgrade later).
Corsair 2GB DDR XMS3200PT TwinX (2x1GB) CAS3
£187.99 inc VAT
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB)
£135.11 inc VAT
Asus P5B Deluxe (Socket 775) PCI-Express DDR2 Motherboard
£140.99 inc VAT
Sapphire X1600 Pro 256MB DDR2 AVIVO TV-Out/DVI (PCI-Express)
£64.61 inc VAT
Enermax Noisetaker 535W EG565AX-VE(W) SFMA ATX2.0 SLI Compliant PSU
£64.61 inc VAT
Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache
£74.01 inc VAT
CoolerMaster Stacker 830
£175.06 inc VAT
Thanks, and suggestions are very much welcome!
£370.11 inc VAT
£187.99 inc VAT
£135.11 inc VAT
£140.99 inc VAT
£64.61 inc VAT
£64.61 inc VAT
£74.01 inc VAT
£175.06 inc VAT
. What are you planning to add to it that requires that much space anyway?
