What do you mean by 'display screen'? If you mean will you be able to see anything on the screen then no, as the CPU has no onboard graphics.
Nor does the mobo.
YepNor does the mobo.![]()
I'd also use the manufacturers website, this would be the page you need, assuming your using W7 64-bit. On-top of that you would need graphics card drivers.Thanks Guys, Im gonna build it now and as you said slot the gfx card in when it comes, in the youtube vid I watched it said after loading the OS to upload drivers off the manufacturers website instead of software is that what you would also recommend?
Yes I will be using win 7 64 bit, Looking through the list on the link you gave, sorry if this is a stupid question but do you download everything or just the version with the most recent date? i.e in the chipset list there are 4 versions given, in the audio there are 2 versions, there is also a hotfix - do I download that aswell, sorry its my 1st time doing this
yo have a reasonable PSU in the system.
I'd look at the second hand GPUs , GTX260/275/280/460 or >= HD 5670
The HD6450 or GT520/G620 graphics are fine for general usage or watching a film but fairly useless for gaming.
For the same cost you'll get a second user GPU with more guts
AD
im not really in to gaming
is gtx 760 compatible?
