I have a problem, the 8-pin power cable (CPU) doesnt reach the slot the only way it does is the following (check pictures) and I want to ask if it is bad to attempt running it like that or should I wait for extension cable?
Also a very noob question which is the top side of the HDD with the metal or with the electronic part?
