right so i decided to build a new rig what with it being christmas and all ;p *evil laugh*
I have built loads of pc's in the past, but 2008 is when i started looking at water cooling. I say start, because I chose a ready made kit.
http://www.thermaltakeusa.com/product/chassis/fulltower/tai-chi/vb5000sna.asp
anyway long story short, my old system was:
MB: Maximus Extreme
CPU: Q6600
Memory: XMS1333 4GB DDR3 (4X1GB) 1333MHZ
Graphics: 2 single ATI X3870 PCI-E in SLI
HardDrives: 3 x 36GB raptors
PSU: 1500W Thermaltake ;p modular future proof
so far I have bought another case&psupply, and moved it all into that the new case taking with me a few components ***in short term.
New system so far Win 7 64 prof
MB: Asus Rampage III Extreme --took me a while to get it to work with iphone
CPU: i7 950
Memory: XMS1333 4GB DDR3 (4X1GB) 1333MHZ ***
Graphics: single ATI X3870 PCI-E in SLI ***
HardDrives: OCZ IBIS 100GB (zoom zoom)
I have ripped out bits of thermaltake case watercooling that i didnt like (pump&res) and replaced with:
XSPC Acrylic Dual 5.25" Reservoir for Laing D5
Swiftech Laing D5 Vario MCP655
EK-Supreme HF - Full Nickel CPU Water Block (had the old supreme b4)
Only slight problem i had with the EK supreme was that i could only get 3 of the screw pins out, so i couldnt see what jet plate was in, it looks from the diagram that it must be plate one as its the only one missing out of the 5...shame that I cant change it but pin head wouldnt turn, and its kinda worn now with me trying to force it...sigh
i downloaded FAH which is good and easy to use, maxed out my processors and ran it for a while... temp went to 70c is this too hot for stock? ..should i replace the radiator? or have i knacked the ek supreme?
What do you reckon to graphics cards? wait for the 6890's?
Memory? I keep lookin at the two 24gb that are on OC atm
has any one installed that amount of ram in this mb?
MB: Maximus Extreme
CPU: Q6600
CPU: i7 950
