The tubes are slightly long, but i wanted to avoid any form of kink or slight bend, so i was playing it abit on the safe side. especially this being my 1st watercooled build.
I did want it to be res>pump>UT45 rad>UT60 rad>CPU>GPU>RES
But the QDC is too big. and i didnt want the tube to bend too much. so i decided on this config and i actually quite like it, becuase it looks pretty neat and uniform.
The hardware will be changed maybe end of the year or early next and an extra 240 rad will probably added to the loop, so things will change and hiopefully then i can sort the tubing to the way i wanted it to
