- 6 Feb 2010
Who cares about the difference of between 2-5fps on average frame rate when it is in the 50fps range? You can't claim that it is faster until you got the minimum frame rate results as well, as those are the scenes that truely put the CPU to the test, rather than during the 50fps "laid-back" scenes.also i5 at 5ghz is slower than a phenom in years biggest fps game
so funny![]()
Also the Asus P8P67 Deluxe that was used in testspot is FAR from the best motherboard available...it is slower than lots of other 1155 motherboard out there, including its little brother the Asus P8P67 Pro. In case you don't realise, decent and average motherboard can easily make a couple of fps difference despite using the same CPU, same graphic card.
