Bulldozer/Phenom compat help
14 Oct 2011
Can anyone help me? I'm trying to find out what the fastest processor I can stick in my old motherboard is. Problem is it seems like rather an obscure model and I can't find any documentation on it. It's an Asus M3n72-T Deluxe.
Will it take a Bulldozer or a hex core Phenom? I'm looking specifically at the 1100T and the 6100. Assuming either of them will work is there anything else I need to be thinking about that I've overlooked?
This is your board right? http://uk.asus.com/Motherboards/AMD_AM2Plus/M3N72T_Deluxe/#CPUS
Strange that there's only three CPUs listed in the CPU support list... but it seems it can support the X4 965 C2 revision though. Unfortunately all new Phenom chips are C3 revisions, so you may have to try find a second hand one.
I'm quite confused why the CPU list is like that, might be a site error. Looking at the date of the latest BIOS release shows 2009, which is before the hex core release. Looks like you're limited to the Phenom II X4.
I've found out that your board is an AM3 best at phenom ii X4 CPU, I believe it can't take bulldozer or X6. So you will have to upgrade to the newer boards im afraid.
I get the impression that they made about 10 of these boards, their support is terrible because I think I'm the only person on the planet that has one. Try and find one for sale, it's like they don't exist. With them being so rare it's pretty impossible to find anyone who's got one and tried out other CPUs.
Anyway I'm still pretty confused, got about as many yes-it-will-works as no-it-wonts. Can anyone give me a catagorical answer as to whether or not those two specific CPUs will work? I get the impression that the Bulldozer is a no go, but people seem pretty devided on the 1100T. If the 1100T isn't going to work will an X4 980?
I have one of them boards.
Unfortunately the bios hasn't been updated for a long time.
1102 is the latest BIOS and that does support the X4 965.
As to the 980 i cant say, haven't got one to test.
X6 was a no go tried with a 1055T.
Honestly, just get the 955. It overclocks as well as the 980 and may have a better chance working in your motherboard.
That sounds the safes bet, actually get the 965 as its only £4 more and stock clocks 200Mhz more.
